Fujor
Message 31 of 37
Re: Slow download speeds and occasional drop outs
Sadly it has started doing it again.
Lots of drop outs yesterday, and takes a while for router to connect to Internet only for it to drop out straight away
Fujor
Message 32 of 37
Just a further to this. A good few years ago and a couple of properties ago I had a similar albeit not as severe problem.
Took ages to get a solution, ended up with open reach telling me there was a fault at the exchange, followed by no fault at the exchange. A couple of days later half a dozen open reach engineers were in the village.
Not saying that's the issue of course but something is clearly causing these drop outs. Hardware sorted it for a few days but it's back again so I wonder if something was done in the background that improved stability?
Fujor
Message 33 of 37
Also this time when the router was disconnected I did a quiet line test. There was intermittent hiss and crackle in between the quiet and when router connected again it went full quiet
Matt-S
Moderator-Retired
Message 34 of 37
Hi @Fujor,
I can see that the engineer was out today and completed a fix outside the property.
Can you test the connection over the next few days and let me know if the fault is fixed?
Matt
Fujor
Message 35 of 37
Yes thank you. I will keep an eye on it. Its been fine all morning but cut out shortly after the fix. There is work going on at my exchange today so will chalk that one off
Will keep monitoring it however.
Fujor
Message 36 of 37
Hi Matt
Internet has been a lot more stable since the fix. It all seems good now.
Thank you for helping me with this problem
Cheers
Matt-S
Moderator-Retired
Message 37 of 37
Hi Fujor,
Thanks for letting me know that the fault is now fixed.
Cheers
Matt
