Fujor
Message 11 of 37
Re: Slow download speeds and occasional drop outs
I only have the one phone line in this house.  There's a few ethernet ether but they are currently not in use.
It's a master socket 5C. The phone and the router is plugged into through a filter . I haven't touched this since the open reach engineer plugged it all in when he did the initial connect a few weeks back.
The internet drop outs are occurring regularly and can last in some cases 30 minutes.
Keith_Beddoe
Message 12 of 37
Try connecting to the test socket as shown below, and see if it still disconnects.
NTE 5C Test socket checkNTE 5C Test socket check
Fujor
Message 13 of 37
Ok I have done that and it does seem to be more stable. I will give it a couple of days and see how it goes.
What does mean if face plate causing the instability?
Keith_Beddoe
Message 14 of 37
I assume you have no extension socket wiring connected to that extension block that you can now see on the left?
Fujor
Message 15 of 37
No I have no extension wiring there.
Still having the same issues with losing internet service. Dropping out with same regularity and for same duration.
Keith_Beddoe
Message 16 of 37
If its dropping out at the test socket, and there is no noise on your phone line, then there must be an external fault, or the home hub is faulty.
Do the lights on the home hub change colour when you get the disconnections?
Fujor
Message 17 of 37
The lights don't always change colours. More often it will be orange without the "B" symbol and stay off for some time but quite often it'll stay blue and drop momentarily but keep dropping for a few minutes.
Keith_Beddoe
Message 18 of 37
All you can do is to report the problem to BT, if you have not already done it.
You are entitled to a free engineer visit, as its a new connection, especially as your speed is much lower than it should be.
If you had a spare home hub or another VDSL router, you could prove whether its the home hub.
Sometimes a factory reset of the home hub can help, just in case its a corrupted user profile file.
Fujor
Message 19 of 37
Done a factory reset so will see if that helps.
If not is there a better phone number to report this to BT rather than the usual customer service number?
Cheers
Keith_Beddoe
Message 20 of 37
Cheers
Not really, but if you cannot make any progress with this, then a moderator can be asked to assist, but they are normally very busy, and it can take a few days before they can look at it.
I will ask them, just in case they are not too busy.
