Fujor
Message 21 of 37
Re: Slow download speeds and occasional drop outs
Thanks for the help.
If not heard anything by tomorrow I'll try and go through the normal channels
Cheers
Matt-S
Moderator-Retired
Message 22 of 37
Hi @Fujor,
Welcome back to the Community 🙂
Thanks for taking the time to post, sorry to hear that you are experiencing slow speeds.
It looks like your broadband profile has been banded to 40/10 so we will need to take a look at this to get to the bottom of why this has happened. I've sent you a Private Message with details on how you can get in contact with the mod team.
Matt
Matt-S
Moderator-Retired
Message 23 of 37
Hi @Fujor,
I have checked the network and the connection looks pretty good.
I have arranged for a new BT Smart Hub to be sent out to you to see if this helps the dropping connection and WiFi speeds.
I have also made a few tweaks to the broadband profile to see if we can get you a little more speed.
Can you test the connection over the next week and let me know if it looks any better?
Matt
pippincp
Sage
Message 24 of 37
I think @Matt-S  means he made a few tweaks. I don't think your broadband profile is on twitter.🤣
Fujor
Message 25 of 37
Hi Matt
Thank you, I will keep monitoring it for the next week and will report anything here
Cheers
Matt-S
Moderator-Retired
Message 26 of 37
No idea what you're talking about @pippincp  😅🤣
pippincp
Sage
Message 27 of 37
Of course not @Matt-S 🤣🤣🤣😂
By the way.😂
Matt-S
Moderator-Retired
Message 28 of 37
Hi @Fujor,
I hope you are keeping well?
Just checking in to see if the new BT Smart Hub has helped with your connection?
Matt
Fujor
Message 29 of 37
Hi Matt
TThanks for the message, yeah it seems to be much better now. No drop outs and speed has been more stable however seems slow on 2.4ghz but that could be down to distance from router.
Thank you for the help, problem solved.
JohnC2
Moderator
Moderator
Message 30 of 37
Hi @Fujor that's good news and I'll let @Matt-S know when he is back in the office next week.
cheers
John
