Moderator
Moderator
Message 11 of 16
Re: Slow evening speeds with Infinity 1 and problems with speed tester
Thanks for taking the time to do that @DavidMc1984. It may take us a couple of working days to pick it up but we will do all we can to help you.
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Moderator
Moderator
Message 12 of 16
Hi @DavidMc1984,
Thank you for sending in your details. I've ran a few checks on your connection and its picking up a capacity issue at the exchange. In order to get BT Wholesale to investigate this further, please could you run a speed test this evening using the link - http://speedtest.btwholesale.com/
You'll need to run that test using the wired connection. Once the first test completes, please run the further diagnostics.
PaddyB
Community ModeratorPaddyB
Kudos”
DavidMc1984
Message 13 of 16
Thanks Paddy I have posted the image of the test and then an image of the further diagnostics test.
Moderator
Moderator
Message 14 of 16
Hi @DavidMc1984,
Thank you for posting back and for running those tests. I've spoke to BT Wholesale today and they're making a few changes on the network. These changes should take affect over the next 24 - 48 hours and will improve the speeds during peak times.
I'll follow up with you again on Friday to see how the connection is performing.
PaddyB
Kudos”
Moderator
Moderator
Message 15 of 16
Hi @DavidMc1984,
I gave your home number a quick call, I'm sorry I didn't get speaking to you.
I've ran a few checks on your connection and the work carried out by BT Wholesale has been completed. Your connection has been moved onto a less congested circuit.
How are thing with your connection at your end, have you noticed an improvement during peak times?
PaddyB
Kudos”
DavidMc1984
Message 16 of 16
Hi, sorry has been away for 2 days so was unable to test, testing it now  bt wholesale test shows massive improvement, hitting 53mb.
I'm glad to have speed backs where I can stream again thanks 😄
Will report back here again tomorrow just to clarify once more
