Rob290482
Newbie
Message 1 of 7
Slow infinity 1 download
Hi, i signed up to BT Infinity 1 with guaranteed 31mb down and 9mb upload. It was installed on 16th March and its still not any faster than 21mb download. The upload is great at close to 10mb. I have taen a screen shot of the homhub 5 data. its as follows:
Do numbers 8, 9, and 10 look decent or are any too high / low? You will see i switched off the router 4 days ago. The data was almost the same when i switched it off.
Rob
4. Board version: BT Hub 5A
5. DSL uptime: 4 days, 00:50:06
6. Data rate: 9917 / 21670
7. Maximum data rate: 9917 / 25305
8. Noise margin: 5.8 / 5.4
9. Line attenuation: 28.1 / 24.7
10.. Signal attenuation: 28.1 / 21.9
6 REPLIES 6
Message 2 of 7
Re: Slow infinity 1 download
Where is your router plugged in? In an extension or the master socket?
Rob290482
Newbie
Message 3 of 7
Is connected to the original BT master socket. However, that said, there is a flat rectangle box on the wall just next to it that looks like the cable has been joined at 1 point in the past. The lid opens and looks like it cable was too short so its been lengthened by BT?
Are the Noice Margins and attenuation levels normal?
Rob
Message 4 of 7
your stats look ok with noise margin about normal 6db
can you enter your phone number and post results  remember to delete number  https://www.btwholesale.com/includes/adsl/main.html
Rob290482
Newbie
Message 5 of 7
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
High
Low
High
Low
FTTC Range A (Clean)
47.9
35
7.9
5.8
Available
FTTC Range B (Impacted)
34
16.6
7.2
3.7
Available
WBC ADSL 2+
Up to 13
10.5 to 15
Available
WBC ADSL 2+ Annex M
Up to 13
Up to 1
10.5 to 15
Available
ADSL Max
Up to 8
7 to 8
Available
WBC Fixed Rate
2
Available
Fixed Rate
2
Available
Other Offerings
Fibre Multicast
Available
Copper Multicast
Available
Rob290482
Newbie
Message 6 of 7
Should i need to reset the homehub after so many days? Its been left on now for almost 5 days i think.
Rob
Message 7 of 7
you should not need to reset the hub manually as it works best on a stable 24/7 connection
your connection/attainable speed is lower than bottom estimated speed so are you using the test socket with a filter to see if that improves your connection
