mbowles1
Newbie
Message 1 of 4
Slow internet speeds ~200kbps
Hi my internet is much slower than it should be. I used to get around 1mbps which I was fairly happy with but now it is ~200kbps. downloads take a ridiculous amount of time and considering I should be getting 72.2mbps according to home hub settings this is quite bad.
I obviously don't expect to get 72.2mbps but I would prefer more than a fraction. If anyone can help it would be greatly appreciated.
I have BT home hub 3.0 and I think there is BT infinity too.
Below shows info from helpdesk
3 REPLIES 3
Message 2 of 4
Re: Slow internet speeds ~200kbps
you are using a modem and hh3 so there are no hub stats available as held by modem - unless modem unlocked
run btspeedtester and when first test completes then run diagnostic test and post results  MUST be done with direct wired conenction
btspeedtester
mbowles1
Newbie
Message 3 of 4
I believe this is the data you need.
Deathtrap3000
Recognised Expert
Message 4 of 4
You have a fault. You are on the infinity 2 package. I would call BT and get an engineer out.
