Message 21 of 33
Re: Slow speed on Superfast Fibre 2
What internet connection time does hub show?
snapper69
Message 22 of 33
Yesterday afternnon it was showing 1 day 0 hours 30 mins, but it was about 24 hours since that big power cut.
snapper69
Message 23 of 33
Checked the router information today and it indicated that the router had been running since about 10 am on Saturday, when we were out. It also shows that the data rate is 14.53 Mbps / 23.73 Mbps and max data rate is 14610 / 27871. Test from router still doesn’t work, but a test on the Uswitch site shows 22 Mbps on download and 14 on upload.
I am really getting annoyed now and beginning to wish that I hadn’t signed up with BT. What is the best way to complain?
Sage
Sage
Message 24 of 33
Can you post the full stats again.
snapper69
Message 25 of 33
Firmware updated
Product name:
BT Hub 6A
Serial number:
+084316+NQ91639445
Firmware version:
SG4B1000E01E
Firmware updated:
13-Aug-2019
Board version:
1.0
Gui version:
1.105.0
DSL uptime:
0 Days, 11 Hours 20 Minutes 31 Seconds
Data rate:
Maximum data rate:
14610 / 27264
Noise margin:
6.3 dB / 5.9 dB
Line attenuation:
19.8 dB
Signal attenuation:
0 dB / 19.8 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
103 MB Uploaded / 1158 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
SKYDB4CC
2.4 GHz wireless channel:
Smart (Channel 11)
5 GHz wireless network name:
SKYDB4CC-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
98:1E:19:FD:19:65
Software variant:
Boot loader:
9.2.0
snapper69
Message 26 of 33
It says that it rebooted about 9 am, while we were both at work and now our landline isn’t working.
Sage
Sage
Message 27 of 33
Report a phone line fault. Don't mention broadband.
snapper69
Message 28 of 33
Ok, thanks.
snapper69
Message 29 of 33
Will they look at the broadband at the same time, even if I don't mention it?
Sage
Sage
Message 30 of 33
They don't need to, you have a line problem not a broadband one even though your broadband is affected.
Sort the line problem and you BB should return to normal.
