aribrave
Message 1 of 44
Slow speeds after moving to a new home. Superfast Fibre Plus
Hello,
After moving in to my new home I experiencing still speeds way below average. If someone can look into it. Here's my ADSL checker screenshot from BT Wholesale website:
 And technical log as well:
Product name:
BT Hub 6A
Serial number:
+084316+NQ71695075
Firmware version:
SG4B1000B540
Firmware updated:
29-Sep-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 8 Hours 59 Minutes 50 Seconds
Data rate:
20.00 Mbps / 40.00 Mbps
Maximum data rate:
27681 / 63375
Noise margin:
10.6 dB / 12.1 dB
Line attenuation:
14.3 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
33362 MB Uploaded / 84257 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-ZC6S
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-ZC6S
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
Off
MAC address:
F4:6B:EF:2C:39:57
Software variant:
Boot loader:
7.33.1
Best regards,
Michael
43 REPLIES 43
Distinguished Guru
Distinguished Guru
Message 2 of 44
Re: Slow speeds after moving to a new home. Superfast Fibre Plus
Conneect to the test socket with filter to see if speeds improve. Do a quiet line test 17070 option 2  any noise report a line fault on 151, don't mention broadband.
aribrave
Message 3 of 44
As follows, no noise on line test
aribrave
Message 4 of 44
New check due to lacking cabinet and exchange info.
Message 5 of 44
Looks like DLM has banded your line at 40M due to instability. Have you been experiencing drop outs or hub restarts?
Or your line has been mis-provisioned at 40M download.
aribrave
Message 6 of 44
I had some drops for last week, but now it seems stable.
Message 7 of 44
Keep a stable connection and DLM should restore your speed, might take weeks rather than days though. Don't be tempted to reboot your hub.
aribrave
Message 8 of 44
Thank you, I'll keep an eye on it for the next few weeks then.
aribrave
Message 9 of 44
After raising few faults and having some conversations with customer service I'm unable to see any improvements. After few weeks I'm experiencing even lower speeds then before.
Distinguished Guru
Distinguished Guru
Message 10 of 44
Can you repost your hub stats?
