aribrave
Message 21 of 44
Re: Slow speeds after moving to a new home. Superfast Fibre Plus
 Hello, it seems new data rate been set. But still connection dops as we can see in a stats.
Product name:
BT Hub 6A
Serial number:
+084316+NQ71695075
Firmware version:
SG4B1000B540
Firmware updated:
03-Feb-2019
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 5 Hours 3 Minutes 9 Seconds
Data rate:
20.00 Mbps / 55.00 Mbps
Maximum data rate:
28035 / 67086
Noise margin:
10.8 dB / 9.4 dB
Line attenuation:
13.5 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
4217 MB Uploaded / 33905 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-ZC6S
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-ZC6S-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
F4:6B:EF:2C:39:57
Software variant:
Boot loader:
7.33.1
Techwizz
Message 22 of 44
I wonder why you've been put on 55/20 not 80/20...
aribrave
Message 23 of 44
That’s good question. Now almost without any connection dropping it should be set to a proper values. Or could it be set manually?
Techwizz
Message 24 of 44
Unfortunately, you can't. A mod will have to request it to be changed.
aribrave
Message 25 of 44
Thank you, guess I need wait now for a mod response. In the meanwhile connection drop again. After so many fault reports it should be better than this.
Techwizz
Message 26 of 44
Ok, we need to find out what's causing the connection drops before this can be done. Is the line noisy? If not, do you know of any electrical items in your home that may be turning on/off at the times of connection drops? Please post the line stats from your BT Smart Hub again.
aribrave
Message 27 of 44
I don’t think any of the devices causing this. I’ll post new stats in a sec. The line is silent on test.
Product name:
BT Hub 6A
Serial number:
+084316+NQ71695075
Firmware version:
SG4B1000B540
Firmware updated:
03-Feb-2019
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 15 Minutes 37 Seconds
Data rate:
Maximum data rate:
27575 / 63887
Noise margin:
10.4 dB / 8.4 dB
Line attenuation:
14.3 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
8206 MB Uploaded / 37258 MB Downloaded
Broadband username:
BT Wi-fi:
Active
BTHub6-ZC6S
Smart (Channel 11)
BTHub6-ZC6S-5
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
F4:6B:EF:2C:39:57
Software variant:
Boot loader:
7.33.1
Maybe my Hub logs will be helpful?
Techwizz
Message 28 of 44
Ok, your line attenuation has increased from 13.5 dB to 14.3 dB which would suggest that there's a high resistance fault somewhere. You can post the Hub logs if you like just to see how many disconnections there have been. Select "WAN" from the dropdown list in the event log and paste what's shown.
aribrave
Message 29 of 44
I now replaced my micro filter. I’ll try to post my logs as txt.
Message 30 of 44
No it doesn't, it just means that the speed has increased due to more frequency bins in use hence re-calculation of attenuation over a wider frequency range.
