aribrave
Message 41 of 44
Re: Slow speeds after moving to a new home. Superfast Fibre Plus
Good morning,
I've noticed my speed increased since last few days. But I still can see my connection droping once per day for example.
Here are some fresh statistics from BTHub:
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084316+NQ71695075
Firmware version:
SG4B1000B540
Firmware updated:
03-Feb-2019
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 1 Hours 9 Minutes 10 Seconds
Data rate:
20.00 Mbps / 76.48 Mbps
Maximum data rate:
23231 / 77151
Noise margin:
7.3 dB / 3.3 dB
Line attenuation:
13.5 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
12319 MB Uploaded / 49641 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-ZC6S
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-ZC6S
5 GHz wireless channel:
Smart (Channel 44)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
F4:6B:EF:2C:39:57
Software variant:
Boot loader:
7.33.1
Techwizz
Message 42 of 44
Your downstream rate has increased because DLM has dropped your target SNRM to 3 dB, that is why you're seeing drops once per day. Hopefully, the drops will stop now.
aribrave
Message 43 of 44
Thank you for your help. We close this one for now as fixed.
Best regards
Moderator
Moderator
Message 44 of 44
@aribrave  That's great, I'm glad your speed has improved. I'll let @JohnC2 know you've posted.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
