Message 11 of 44
Re: Slow speeds after moving to a new home. Superfast Fibre Plus
I would say your line has been wrongly provisioned, like @licquorice pointed out. I think this requires mod intervention.
Message 12 of 44
Message 13 of 44
Thanks for posting the stats. If you've only had a few disconnects, that banding looks really harsh, so I still think it's what I said above. Uptime is only 19 hours, was that a manual resync?
Message 14 of 44
IP lease time is set by default to 24 hours if it counts to connection stats.
Sage
Message 15 of 44
A mod should be along soon.
Message 16 of 44
No, lease time is totally unrelated to DSL uptime.
Sage
Message 17 of 44
It doesn't and is not recorded in the tech logs.
Message 18 of 44
So dsl uptime is not affected in stats by renewing IP address
Message 19 of 44
No. Did you reboot the Hub just before the time shown for DSL uptime? If not, then it was a drop in connection. Just trying to work out if there's a fault or not.
Message 20 of 44
No, hub is on all the time. Fault been flagged as fixed this morning again.
