Message 31 of 44
Re: Slow speeds after moving to a new home. Superfast Fibre Plus
Message 32 of 44
Could you please filter the event log by setting category to WAN and then repost results.
Message 33 of 44
Filtered by WAN. Last drop is caused by changing micro filter.
https://www.dropbox.com/s/llrub6dvk7sanyo/event_log%281%29.csv?dl=0
Message 34 of 44
@licquorice, it could also be that. But, an increase in line attenuation, especially significantly, can also indicate a fault. Because the OP is getting frequent disconnects, that seems more likely.
Moderator
Moderator
Message 35 of 44
Hi @aribrave,
I've sent you a private message so we can take a look into everything for you going forward.
DanielS
Message 36 of 44
After engineer visit the fault been fixed and been informed that I cannot reach higher speeds than 50-52 because the distance from the cabinet too great. Should I expect anything more after few weeks of stable connection anyway?
Newest stats after visit:
Product name:
BT Hub 6A
Serial number:
+084316+NQ71695075
Firmware version:
SG4B1000B540
Firmware updated:
03-Feb-2019
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 1 Hours 15 Minutes 27 Seconds
Data rate:
20.00 Mbps / 56.15 Mbps
Maximum data rate:
23995 / 66890
Noise margin:
15.3 dB / 6.3 dB
Line attenuation:
13.5 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
4351 MB Uploaded / 6279 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-ZC6S
2.4 GHz wireless channel:
Smart (Channel 6)
5 GHz wireless network name:
BTHub6-ZC6S-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
F4:6B:EF:2C:39:57
Software variant:
Boot loader:
7.33.1
Message 37 of 44
If connected to a Huawei cabinet, then you'll likely see G.INP activated and a lower target downstream SNRM give you more speed.
Message 38 of 44
Hello,
Appreciate your help. I’ll wait couple days and see how it goes. Fingers crossed.
Moderator
Moderator
Message 39 of 44
Hi @aribrave thanks for speaking with me earlier and now the engineer has repaired the fault on the line the connection speed should improve.
Cheers
John
Moderator
Moderator
Message 40 of 44
Hi @aribrave Has your connection speed improved over the last few days?
cheers
John
