Message 1 of 32
Slow speeds on infinity
Hi,
Feel like im going round in circles....
For the last fortnight (after over 3 years of no issues) i have noticed my internet speeds drop from 30mb to 7mb. This has affected things like sky q on demand etc.
Had a Bt contractor come out monday to check my equipment etc, and even with his own hub and wires etc he was still getting readings of 7mb, then another time 6mb, then one time 11mb, all whilst on ethernet. He declares that there is also a lot of packet loss when he starting using a ping program.
Problem was reported back to BT (in a very laboured way!) and today an openreach engineer came. He plugged some device into the socket and got a reading a 34mb, telling me everything was fine. (im guessing he was just checking the sync speed) Despite me trying to tell him that i wasnt getting that speed even using different equipment etc, he said he would check the cabinet in case anything was "loose".
Anyways cut short, hes reported back everything is fine, but im still not getting any more than 7mb. HELLLP
also want to point out that my upload speed is also 7mb - which says to me that when traffic come down the line, something is going wrong.
Any help is greatly received as i really have little faith that BT will sort this.
31 REPLIES 31
Sage
Message 2 of 32
Re: Slow speeds on infinity
Could you post your router stats  please? See HERE for how to.
Message 3 of 32
which exchange and cabinet are you on?
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with ethernet connection  can you run when download appears ok and then again when poor
Message 4 of 32
Product name:
BT Hub 6A
Serial number:
+084316+NQ64332438
Firmware version:
SG4B1000B522
Firmware updated:
23-Jan-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 8 Hours 23 Minutes 21 Seconds
Data rate:
8.50 Mbps / 32.77 Mbps
Maximum data rate:
9785 / 33058
Noise margin:
6.4 dB / 6.1 dB
Line attenuation:
20.5 dB
Signal attenuation:
0 dB / 20.5 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
1928 MB Uploaded / 754 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-PH7H
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-PH7H
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
24:20:C7:46:9A:3B
Software variant:
Boot loader:
7.33.1
Message 5 of 32
LONG EATON cabinet 21
 this is a good time
1. Best Effort Test: -provides background information.
 Download Speed
 24.33 Mbps
0 Mbps31.72 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 24.33 Mbps
 For your connection, the acceptable range of speedsis 27.5 Mbps-31.72 Mbps .
 Additional Information:
 IP Profile for your line is - 31.72 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 7.37 Mbps
0 Mbps10 Mbps
Upload speed achieved during the test was - 7.37Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Please visit the FAQ if you are unable to understand the test results.
Message 6 of 32
was the btspeedtester just run?  as it is peak time I would have expected poor download speeds
Message 7 of 32
strangely struggling to get a bad reading at the min
If i use ookla speedtest it actually gives me results of 7mb, so which one is right?
Message 8 of 32
only btspeedtester results with wired connection are acceptable
Message 9 of 32
yes
Message 10 of 32
this is all very odd to me, and im a little out my depth.
when i do a different speed test on my iphone, it shows my wifi speed at only 6-7mb? why is this?
