Message 11 of 32
Re: Slow speeds on infinity
Wireless speed is susceptible to interference and often download speed lower hence why where you run btspeedtester it is only accepted when you run it with an Ethernet connection
if you have .the MYBT app try running the test my speed
Message 12 of 32
just tried that and it failed
Message 13 of 32
I just tried the test my speed and it worked ok for me so it is working
Message 14 of 32
Just ran it now and it says download 2mb upload 8mb
Message 15 of 32
I seem to get different results every time I run a test even on wired!
Message 16 of 32
If you can get btspeedtester diagnostic test to work the post results
Message 17 of 32
1. Best Effort Test: -provides background information.
 Download Speed
 26.65 Mbps
0 Mbps31.72 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 26.65 Mbps
 For your connection, the acceptable range of speedsis 27.5 Mbps-31.72 Mbps .
 Additional Information:
 IP Profile for your line is - 31.72 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 3.08 Mbps
0 Mbps10 Mbps
Upload speed achieved during the test was - 3.08Mbps
 Upstream Rate IP profile on your line is - 10 Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Sage
Message 18 of 32
Try downloading a 512MB test file from HERE, should tahe about 3 mins for a 30Mb connection.
Message 19 of 32
Download speed looking ok at 26.65mb
Message 20 of 32
138kbs speed im getting downloading that file
very odd!
yet the wonderful wholesale speed test says im getting 24mb still? confused!
