Message 21 of 32
Re: Slow speeds on infinity
If the wholesale speed checker is reporting high speeds,27mbs but when I try and download anything on laptop by wired connection (no other devices connected) I get very low speeds.
Is this is sign of congestion?
Message 22 of 32
Is the laptop connected directly to the home hub with an Ethernet cable?
The wholesale speed checker would be correct. What are you trying to download, that is showing a low speed?
It could be the site you are downloading from which is slow?
What download speed is it showing?
Message 23 of 32
Yes connected by Ethernet. It was firstly a test file from the site listing earlier in the thread.
Then also just a program from another website
Also ran several other speed check programs
And then also tried to download chrome
Message 24 of 32
Speeds were anything between 1mb and 3mb
Message 25 of 32
And it’s a new laptop windows 10 etc
Message 26 of 32
Was that 1-3 MB/s?
Downloads on Windows computers are expressed as megaBYTES/S
3MB/s  =  24Mbs/S (megabits)/S  which is very close to the BT Speedtester results.
Message 27 of 32
Sorry it was 113kbs I’ve just checked
Message 28 of 32
Then that is giving you the wrong result.
The BT Wholesale tester result is the only one that BT will accept, as it tests at the last point before it reaches the core of the Internet.
Message 29 of 32
Hi Keith, I accept that bt speed test gives that reading, but I can’t physically download anything anywhere that speed. Where do you think the problem lies?
Is it possible that when I want more data down then line than a Speedtest uses, ie downloading an app or program, that the data gets congested and slows right down?
Message 30 of 32
Baring in mind everything was fine two weeks ago, and only now I have these issues!
