Bat21
Message 1 of 10
Slow speeds with old damaged cable
I have live at my property here for 33 years.
When I first moved in a 'temporary interruption cable' was run out to the very small village here. As it was just placed in the hedgerow over the years this cable has been cut, ploughed up and generally damaged in many ways.
Although I am paying for Fibre Broadband with BT, the download speed is only around 16mbps at best. There are 8 houses in the village here all fed off the same cable but we all have differing download speeds, my two neighbours connections are approximately 50% faster than mine, I guess this is down to the many repairs in the cable and more so how each repair was effected.
How do I go about getting this cable replaced or at least repaired to a satisfactory standard that can deliver faster speeds.
9 REPLIES 9
pippincp
Sage
Message 2 of 10
Re: Slow speeds with old damaged cable
Enter your phone number HERE and post the result. Remove number beforehand.
Post hub connection stats.
HH6 advanced settings/technical log
HH5 troubleshooting/helpdesk.
imjolly
Message 3 of 10
As you have a broadband connection then your phone must be working.
Check for line noise. Dial 17070 option 2 should be silent and best with corded phone
Bat21
Message 4 of 10
Keith_Beddoe
Message 5 of 10
Seems about right for your line.
These are actual connection speeds, actual measured download speeds will be lower, owing to transmission overheads.
Bat21
Message 6 of 10
Product name:
BT Hub 6A
Serial number:
+084319+*********
Firmware version:
SG4B1000E01E
Firmware updated:
20-Aug-2019
Board version:
1.0
Gui version:
1.105.0
DSL uptime:
0 Days, 20 Hours 42 Minutes 38 Seconds
Data rate:
1.21 Mbps / 21.97 Mbps
Maximum data rate:
1205 / 22540
Noise margin:
5.8 dB / 6.1 dB
Line attenuation:
30.8 dB
Signal attenuation:
0 dB / 30.8 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
603 MB Uploaded / 12994 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
MI6 ********
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
MI6 ********
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
AC:3B:77:00:**:**
Software variant:
Boot loader:
Bat21
Message 7 of 10
Is the 21.75 acceptable Keith, or is it possible that the cable be replaced or at least looked at?
Keith_Beddoe
Message 8 of 10
That closely matches the figure on the screenshot I posted, and is the fastest your line will support.
Each line is different.
Keith_Beddoe
Message 9 of 10
That would be the figure that takes into account things like line length and levels of crosstalk from other circuits.
Its well above the handback speed of 11.4Mbs, so nothing is going to be done.
pippincp
Sage
Message 10 of 10
Your results show there is nothing wrong with the cable whatsoever.
