Message 1 of 2
Slow speeds
We’ve been with BT for c. 10 months and are suffering increasingly from slow speeds, videos buffering, etc. We’re on BT’s up to 36 mb fibre package and generally get a good WiFi signal round the house and speeds routinely of c. 30 mb. So when things are working they are working pretty well.
When we’re experiencing slow speeds, the WiFi connection seems to be stable and still shows close to or full signal. Am hoping someone may be able to check my stats and see if anything looks obviously amiss. Many thanks in advance. Pete
Product name:
BT Hub 6A
Serial number:
+084316+NQ91283451
Firmware version:
SG4B1000E020
Firmware updated:
01-Apr-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
4 Days, 15 Hours 2 Minutes 45 Seconds
Data rate:
6.84 Mbps / 36.65 Mbps
Maximum data rate:
6836 / 36775
Noise margin:
6.4 dB / 3 dB
Line attenuation:
43.4 dB
Signal attenuation:
27 dB / 43.4 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
12 GB Uploaded / 91 GB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BT Home Network
2.4 GHz wireless channel:
Channel 11
5 GHz wireless network name:
BT Home Network
5 GHz wireless channel:
Channel 36
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
98:1E:19:E4:5D:39
1 REPLY 1
Message 2 of 2
Re: Slow speeds
your stats look ok with 36/6mb connection and noise margin down at 3db suggesting G.INP is active and giving a bit boost to connection speed  connection time is 4 days+ so connection appears stable
