Mustafa_Islam
Message 11 of 21
Re: Slow sync speeds BT Infinity 1
Ok thanks, if it doesn’t correct itself by then, then hopefully i fit into those certain circumstances and it can be reset. I’ll get back to you with the status in the next few days
____________________________
If I helped out then leave my reply a Kudos by clicking the thumbs up button
Mustafa_Islam
Message 12 of 21
UPDATE: It’s been almost 10 days now with no downtimes, but speed is still the same. How long till DLM takes me off the low speed band?
pippincp
Sage
Message 13 of 21
Can you repost your hub stats?
imjolly
Message 14 of 21
It could easily take weeks for DLM to take any action
Mustafa_Islam
Message 15 of 21
Well sh** then. Was hoping speed was increase so I could download my game updates faster for my pc and PS4. You said it could be reset under certain circumstances from tomorrow? Do you know what these circumstances are?
Mustafa_Islam
Message 16 of 21
@pippincp
Product name: BT Hub 6A
Serial number: +084316+NQ73462011
Firmware version: SG4B1000B522
Firmware updated: 13-Jan-2018
Board version: 1.0
Gui version: 1.64.0
DSL uptime: 9 Days, 22 Hours 50 Minutes 16 Seconds
Data rate: 10.00 Mbps / 39.99 Mbps
Maximum data rate: 31092 / 69693
Noise margin: 24.1 dB / 11.8 dB
Line attenuation: 15.3 dB
Signal attenuation:
VPI / VCI: 0/38
Modulation: G_993_2_ANNEX_B
Latency type: Fast Path
Data sent / received: 19951 MB Uploaded / 211556 MB Downloaded
Broadband username: bthomehub@btbroadband.com
BT Wi-fi: Not active
2.4 GHz wireless network name: BTHub6-7R8X_2G
2.4 GHz wireless channel: Channel 6
5 GHz wireless network name: BTHub6-7R8X-5
5 GHz wireless channel: Smart (Channel 36)
Wireless security: WPA2 (Recommended)
Wireless mode: Mode 1
Firewall: On
MAC address: 58:90:43:3B:C1:4B
Software variant: -
Boot loader: 7.33.1
imjolly
Message 17 of 21
I also said it will probably be later than 19th while procedures are decided by ISP and then communicsted to the staff concerned
Mustafa_Islam
Message 18 of 21
Hello again, it’s been about a month. I have left my router plugged in and turned on for the whole time. In the past week the router restarted by itself once and went through a resyncing phase about 3 times. Went from 39.99 downsync to 43.99 then to 44. The noise also went down to around 5-7. Yesterday however it went down to 40mbps and the noise has risen. I have not restarted the hub or done anything to it. How long should I wait for it to go to the speed I am paying for? I am also guaranteed 42mbps. If you could please get a mod involved it would be really helpful. Thank you.
Current tech stats:
Board version: 1.0
Gui version: 1.64.0
DSL uptime: 1 Days, 4 Hours 7 Minutes 46 Seconds
Data rate: 10.00 Mbps / 40.00 Mbps
Maximum data rate: 30966 / 68098
Noise margin: 24.2 dB / 9.9 dB
Signal attenuation:
VPI / VCI: 0/38
Data sent / received: 17294 MB Uploaded / 87120 MB Downloaded
5 GHz wireless channel: Channel 36
Firewall: On
Software variant: -
Boot loader: 7.33.1
Tags (1)
Mustafa_Islam
Message 19 of 21
@imjolly any response?
imjolly
Message 20 of 21
you are obviously still getting connection problems  if speed went up to 44mb then as that is next band up maybe the banding was starting to release but more resets have just knocked you back to where you were in the 40mb band
the forum mods still cannot request a DLM reset and no sign of when that is likely to start either - just wish it would be soon as would help lots of people
