TEREU5
Message 11 of 17
Re: Slow upload and unstable connection
Ok so run for few days with the old one and seems better. Took the socket apart and used filter and according to stats on the old router (not the borrowed one):
but every site that checks speed barely got 20-22Mbps
imjolly
Message 12 of 17
moving to the test socket has significantly increased your connection speed to the top of your expected speed range 53.4mb   There is obviously a problem with your internal wiring or master faceplate or both
 an you run btspeedtester with an Ethernet connection when you think download speed is good  then repeat when you feel download poor and post host results
which exchange and cab are you on - deleted from dslchecker results
TEREU5
Message 13 of 17
I am about 1 mile from exchange.
Exchange code: EMTOWCE
Not sure which cabinet in the area I am connected to  as they are few around.
Ideally would love to have an option of FTTP but don't see that happening anytime soon.
In the past I had some issues with the speed and random drops - after eng visit they switch the pairs of cables as the old one was apparently wet - not sure exactly but I did not asked further  as he was not keen to share (and that's when there was a swap of the master socket)
pippincp
Sage
Message 14 of 17
The exchange and cab number were in the checker results you gave in your second post but you cut them off the screenshot.
Just run the checker again and post the exchange and cab.
TEREU5
Message 15 of 17
Aye sorry. Cabinet 5 🙂
TEREU5
Message 16 of 17
Cabinet P5 FTTC Available from 28th December 2013, expanded 23rd October 2019 Phase BDUK Northants 11b Properties Passed:664 Vendor:Huawei Location:NN12 6EE
For the love of god don't see that cabinet anywhere 😆 unless its at the back of the properties somewhere heh
imjolly
Message 17 of 17
not unusual  mine is nowhere near where code lookup shows on the map.  you would find it if you walked about - eventually
