Message 11 of 15
Re: Slow upload speed
Sorry, here are all the fields
Product name:
BT Hub 6A
Serial number:
+084316+NQ63122154
Firmware version:
SG4B1000E020
Firmware updated:
05-Mar-2020
Board version:
1.0
Gui version:
1.115.0
DSL uptime:
2 Days, 1 Hours 0 Minutes 46 Seconds
Data rate:
10.00 Mbps / 55.00 Mbps
Maximum data rate:
25986 / 90105
Noise margin:
22.6 dB / 15.5 dB
Line attenuation:
27.9 dB
Signal attenuation:
19.7 dB / 27.9 dB
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
2 GB Uploaded / 20 GB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-W72T
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-W72T
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
88:A6:C6:06:A4:B7
Software variant:
Boot loader:
7.33.1
Message 12 of 15
@marcoblt
Thank you,
Can you run the BT Wholesale Speed Test on a wired connection so we can compare the results?
Matt
Message 13 of 15
Hey, see attached.
Ping 8 m/s
Download 48.89
Upload 0
Tags (1)
Message 14 of 15
Message 15 of 15
Hi @marcoblt, thanks for posting those results. The router stats you posted the other day show your upload is 10Mbps so I think there's an issue with the tester rather than your actual broadband if you were actually getting zero upload your connection wouldn't work at all. What upload speed do you get if you try an alternative speed test like ookla?
