soldave
Message 1 of 17
Slower than expected BT Infinity speeds
I've had BT Infinity for around a month now having moved over from TalkTalk, but am not experiencing the speeds I'd been hoping for. Wondering if anyone out there can offer some advice for me. Sorry if there's a bit of information overload below but I wanted to make sure I post all the relevant info I can get.
Smart Hub Info
Product name: BT Hub 6A
Firmware version: SG4B1000223E
Firmware updated: 25-Nov-2016
Data rate: 5.38 kbps / 30.48 kbps
Maximum data rate: 5382 / 30477
Noise margin: 6 / 5.5
Line attenuation: 22.9
BT Wholesale Test Results
Download speed achieved during the test was - 26.63 Mbps
For your connection, the acceptable range of speeds is 20.65 Mbps-29.5 Mbps (have to be clear I'm not sure why this is so slow)
IP Profile for your line is - 29.5 Mbps
BT Broadband Availability Checker
BT Speeds
Speedtest.net
Can anyone tell anything from the info I've posted up, or give me ideas of things to check? I just feel that things should be faster than they are with my Infinity package. Thanks in advance for any guidance you folks can offer 🙂
16 REPLIES 16
Distinguished Guru
Distinguished Guru
Message 2 of 17
Re: Slower than expected BT Infinity speeds
Connect to the test socket and repost the HH stats and also try a quiet line test. 17070 option 2.
soldave
Message 3 of 17
Quiet test does sound quiet.
Connecting via the test socket gives me these results:
Downstream sync speed: 30.55 Mbps
Upstream sync speed: 5.18 Mbps
Data rate: 5.18 kbps / 30.55 kbps
Maximum data rate: 5180 / 30547
Noise margin: 6.1 / 6.1
Line attenuation: 22.8
soldave
Message 4 of 17
Also, for what it's worth here are the Wholesale test results using the test socket:
Message 5 of 17
Do you have any extensions, and are they wired correctly, see below.
Any extensions should be totally dead once you remove the bottom section of the master socket.
If not, then you have "star" wiring which will affect your connection speed.
soldave
Message 6 of 17
No extensions at all in the house. One phone socket, to which only the broadband is connected through a microfilter (no phone connected usually).
Message 7 of 17
You need an engineer visit.
paul_fettes
Message 8 of 17
Are your tests done hard wired with Ethernet cable or wirelessly?
soldave
Message 9 of 17
Tests are done on Ethernet with no other devices connected to the hub.
Message 10 of 17
The ethernet/wireless is irrelevant here. The sync speed of the router is below the minimum expected. An engineer is required.
