aldmunch
Message 1 of 6
Slowish speeds on Infinity 2 after DLM Process
Hello,
I moved in at the start of April and have had an active line for 15+ days now. I'm connected to what I think is  the master socket (first entry point to property), but it is a super old faceplate with no test socket inside to try.
Speedtests show the line working at about 54/15, with the official BTW speedtest showing 51.52/13.26. The modem is synced at  datarates of 20.00 Mbps / 62.18 Mbps. The BT signup page for the service said "Your minimum download speed 67mb".
These are the line stats:
And modem details:
Product name:
BT Hub 6A
Firmware version:
SG4B1000B540
Firmware updated:
08-Apr-2019
Board version:
1.0
Gui version:
1.64.0
Data rate:
Maximum data rate:
27454 / 62571
Noise margin:
10.7 dB / 6 dB
Line attenuation:
14.6 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Given the line stats suggest I should see mid 70s - is there anything I can investigate? Is it worth requesting an engineer visit to look at the 1980s style faceplates / wiring? Or am I likley stuck with the current speed?
5 REPLIES 5
Message 2 of 6
Re: Slowish speeds on Infinity 2 after DLM Process
Any line noise try dial 17070 option 2 should be silent and best with corded phone
Do you have extension sockets in other rooms?
Are you connected direct to filter - no extension cable used
aldmunch
Message 3 of 6
Thanks, line dial test is silent - no noise issues.
There are a number of extension sockets, nothing is connected to them however.
I am using this decent quality 5m RJ11 cablebut I have tried without using the provided RJ11 cable into the filter and not seen any noticable difference.
Distinguished Guru
Distinguished Guru
Message 4 of 6
As you are a new customer and not getting the minimum speed call it in and request an engineer.
Moderator
Moderator
Message 5 of 6
Hi @aldmunch,
Welcome to the community forum.
As your not getting the minimum download speed of 67mb, I'll be able to take a look at your connection and run a few test on your line.
I've sent you an private message with details on how you can contact the mod team.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
Moderator
Moderator
Message 6 of 6
Hi @aldmunch
Thanks for taking the time to chat with me this afternoon.
I have double checked your broadband speed and it's connected at 62Mbps.  I can see that your minimum guaranteed speed is 45Mbps.  As long as your broadband speed doesn't drop below that it wouldn't be classed as a fault condition.  If something does happen that causes your broadband speed to go below that, feel free to post back and we'll happily take another look.
Cheers,
Robbie
Community ModeratorRobbieMac
Kudos”Kudos”
