Message 1 of 3
Smart Hub 2 & Playstation 4 Pro
Hi,
I'm lucky enough to have the BT 900 package.
My Smart Hub 2 has been setup for around a week now and I'm seeing solid 800-900mbps via ethernet and 300-350mbps over WiFi.
My Playstation 4 Pro; however, is jumping all over the place in terms of speeds via ethernet.
If I refresh the connection i.e. setup internet I get 600mbps but every subsequent test has me ~35mbps.
I've tested multiple devices over Ethernet directly into the smart hub 2 and the playstation is the only anomaly.
I'm wasn't expecting the tests to show the full 900 and I wasn't ever expecting actual download speeds that fast either but would have expected at least ~600mbps over Ethernet (cat6 cable).
Any thoughts?
Thanks in advanced.
Alexander
2 REPLIES 2
Message 2 of 3
Re: Smart Hub 2 & Playstation 4 Pro
have you turned of smart setup
Turn Off smart setup
Message 3 of 3
Smart setup is currently on.
(I did try turning it off, rebooting my router and testing again but still showing ~35mbps)
