Message 11 of 12
Re: Smart Hub 2 disconnecting ~every day (DSL Link Down? Noise Margin? DV? DLM? Help!)
Okay - I'll try a factory reset of the SH2 and see if that helps. Can I check - I've noticed the channels that the hub uses for 2.4 and 5 GHz are quite full (according to the WiFi analyser app I used) - could changing the channels to something different do anything to help, or is that likely completely irrespective of the disconnects?
Message 12 of 12
The wifi is completely irrelevant to the disconnects.
