GeeBee1701
Message 1 of 5
Smart Hub 5ghz issues
Hi - just upgraded from HH5 where I was able to use 5ghz wireless connection without issue and was getting my rated speed (46Mbps). On my new Smarthub I have split the 2.4 and 5 Ghz channels (like I did on my HH5) but I am only getting around 10 Mbps on 5ghz (2.4 ghz working fine). I have tried different channels on 5ghz but no difference and also reset my hub. Any suggestions?
4 REPLIES 4
Message 2 of 5
Re: Smart Hub 5ghz issues
Go back to the HH5. If it was working OK why change it. If it ain't broke don't fix it.
adslmax
Message 3 of 5
Did you try forgetting the network name on your PC and relearning it?
Message 4 of 5
Try changing the wireless mode to mode 2
GeeBee1701
Message 5 of 5
Changing to Mode 2 seems to have fixed the issue - thanks
