Any help appreciated!
Solved! Go to Solution.
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Hi @Slimbridge ,
I'm sorry you're experiencing issues with your connection when uploading large files. If you send me in your details, I'll be able to get this investigated.
I've sent you an private message with details on how you can contact the mod team. If you could please follow those instructions. Once I have your details, we'll get this investigated and contact you directly.
PaddyB
Hi @Slimbridge thanks for sending over your details, I've raised a case with the Hub team and they have applied the fix. Can you test this and post back to let me know if its working ok now?
Thanks for the very quick response Neil, when I finish work today I will give it a try and report back.
Thanks @NeilO , that seems to have worked, no problems uploading when I tested. Thanks very much for the quick and effective response!
Hi @Slimbridge brilliant I'm glad that's sorted
