patters1978
Message 1 of 4
Smart hub modem mode replacement
Hi everyone
Just joined bt and have to admit didn’t research the whole can’t be put in modem mode fiasco! Sorry by very shocking that one!
Anyway I’m looking at trying to replace the home hub and unsure what to do, after some research I’m guessing an Openreach Modem will get my infinity connected to my archer c7 but was wondering if the Asus RT-N66u N900 will remove the need for the Openreach Modem and the c7?
If anyone can help it would be appreciated
Cheers
3 REPLIES 3
licquorice
Message 2 of 4
Re: Smart hub modem mode replacement
No, that is just a router, not a VDSL modem/router.  ASUS RT xxxx devices are routers, DSL xxxx devices are modem/routers.
patters1978
Message 3 of 4
Oh ok website said it was! Anyway what about the tp-link ac1600
licquorice
Message 4 of 4
Yep, aka VR600, that will do fine. Make sure you get the V2 version though.
