Message 11 of 49
Smart hub 2
Why does my by hub keep getting slower speeds over a day when I’m getting a good speed coming into the house
it’s not just over Wi-fi  it is the same over wired just gets slower and slower over a day so have to keep rebooting
pits a brand new hub
had 6 openreach engineers out
justmitch
Message 12 of 49
Re: Smart hub 2
if you keep resetting the sh2 daily then the DLM will start to increase your noise margin and reduce your connection speed and if you then continue you will end up in banded profile
is your connection speed dropping during the day?
Message 13 of 49
Re: Smart hub 2
Hi
thank you for reply
what is the answer please if not to keep rebooting it ?
its just dropping at any time day or night last night I rebooted it and was getting 45 by this morning it has gone down to 27 I’m guaranteed 32
I have had 6 openreach engineers out and they have done all they can do they say
last guy spoke about rain engineers to look at it but can’t see but doing that
why if I reboot does it go back to 45 etc is that saying but are supplying me with 45 then it’s the router that is dropping it down to 27 I have tried different routers but all do the same
Message 14 of 49
Re: Smart hub 2
Its the connection speed that is guaranteed, not the download speed.
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Please could you show the connection detail from the home hub.
As you are using the BT Smart hub you can get your connection stats by, Opening a new web browser on your connected device and type 192.168.1.254 or bthomehub.home into the address bar. This will open the Hub Manager.  Click Advanced Settings’ and then ‘Technical log’
Sage
Message 15 of 49
Re: Smart hub 2
Message 16 of 49
Re: Smart hub 2
@justmitch
There was no need to start a new thread, as its only confusing things, so I have merged your two threads.
The page you posted showing your connections speed is unreadable.
Message 17 of 49
Re: Smart hub 2
Hi
Sorry you will have to forgive me I’m 70 and not up with all this
All I know is they told me I’m guaranteed 32 and if it drops below that it’s not right and they send out a small hub which they did and after the 6th engineer had Ben and said it was ok they turned smallhub of
I still don’t understand why when I reboot the hub I get 45 but after some time it goes down to 27 is that saying there is still something wrong with the line because when I ask them to check the line it’s saying I’m getting well over 45
So is it the router or bt line causing the problem
And when the last engineer came out he went right back to green box and checked all the underground connectors right back to my house
Message 18 of 49
Re: Smart hub 2
Sorry I’m not sure about all this as I’m 70 and trying to understand how it all works
Message 19 of 49
Re: Smart hub 2
CHECKER
Telephone Numbeon Exchange MORETON IN MARSH is served by Cabinet 1
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
High Low High Low
VDSL Range A (Clean) 48.9 35 7.8 5.5 30.5 Available Available --
VDSL Range B (Impacted) 47.2 30 7.8 5 25 Available Available --
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand 330 30 -- Available -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 9 -- 8 to 9.5 Available -- Yes
WBC ADSL 2+ Annex M Up to 9 Up to 1 8 to 9.5 Available -- Yes
ADSL Max Up to 8 -- 7 to 8 Available -- --
WBC Fixed Rate 2 -- -- Available -- Yes
Fixed Rate 2 -- -- Available -- --
Observed Speeds
VDSL
Max Observed Downstream Speed (Mbps) 32.63
Max Upstream Observed Speed (Mbps) 8.77
Observed Date 2019-12-06
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- --
ADSL Multicast -- -- -- Available -- --
Premise environment
Status
Bridge Tap N
VRI N
NTEFaceplate N
Last Test Date 27-11-2019
FTTP is not available.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
This line is on a Market A Exchange.
For VDSL or G.fast Ranges A and B, the term "Clean" relates to a line which is free from any wiring issues (e.g. Bridge Taps) and/or Copper line conditions, and the term "Impacted" relates to a line which may have wiring issues (e.g. Bridge Taps) and/or Copper line conditions.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for Datastream is from 30-Jun-2012; the Formal Retirement date for Datastream is from 30-Jun-2014. The Stop Sale date for IPstream is from 17-Jun-2014; the Formal Retirement date for IPstream is from 30-Jun-2014.
If the End User wishes to migrate from their current Broadband supplier they will need to contact the Broadband supplier they want to take service from to arrange for the service to be migrated.
Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number, NAD, UPRN or Access Line ID (ALID) check.
Note: If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service.
Thank you for your interest.
Message 20 of 49
Re: Smart hub 2
You haven't said anywhere how you are measuring the slow speed, is it with a speedtester website or are you looking at the hub line stats? are you connecting via wifi or an Ethernet cable?
