Sage
Message 21 of 49
Re: Smart hub 2
@licquorice wrote:
You haven't said anywhere how you are measuring the slow speed, is it with a speedtester website or are you looking at the hub line stats? are you connecting via wifi or an Ethernet cable?
I don't think that matters much as Max observed is 32Mb which will give about 27Mb after overheads.
Message 22 of 49
Re: Smart hub 2
I’m using Netflix and Speedtest the Netflix one was exactly the same as the openreach engineers test when he did it the Netflix one after I reboot is saying 45 etc and after a few hours it shows the slower speed
Also I have an Xbox and that shows the same results as both Netflix and Xbox is with Ethernet
Message 23 of 49
Re: Smart hub 2
I still don’t understand why it will show 45/48 when rebooted then go down when bt are saying I’m getting 45/48 at my home .
Message 24 of 49
Re: Smart hub 2
it would help if you could post readable hub stats from advanced settings then technical log information
you can you the 'camera' to post a photo
Message 25 of 49
Re: Smart hub 2
I did but unfortunately it’s unreadable sorry will try again
Message 26 of 49
Re: Smart hub 2
Message 27 of 49
Re: Smart hub 2
Post a screenshot, not a photo of a printout
Message 28 of 49
Re: Smart hub 2
your estimated connection speed range is 48/35mb and according to your hub stats your have a great connection of 52mb   connection time is only 9 mins was that you manually resetting hub?
Message 29 of 49
Re: Smart hub 2
Sorry
Can I get into the hub setting on iPad
Message 30 of 49
Re: Smart hub 2
Yes, 192.168.1.254
