mattanorak
Message 31 of 34
Re: SmartHub not suitable for Ultrafast 2
D'oh!
The Ultrafast hub should definitely have "Ultrafast" on the front and come in a box marked "Ultrafast Smart Hub" (or Smart Hub X") - I can't remember and I'm not at home at the moment to check the box.
Dave859
Message 32 of 34
I've been on the phone too BT fttp team who took my serial number of the hub, was told my hub will be updated though special firmware, after a hour or so my upload is now showing as the full 50mbps. This is with the standard BT hub 6 which sort of debugs that the chipset is not capable.
mattanorak
Message 33 of 34
Maybe then that's the difference with FTTP and FTTC - I'm FTTC and was sent a hub with Ultrafast on it.  Anyway, glad it's all working for you now!
pippincp
Sage
Message 34 of 34
The hub 6 for FTTP and FTTC are different, always have benn.
