JonathanAnsell
Message 21 of 34
Re: SmartHub not suitable for Ultrafast 2
The firmware is rolling out now. My Dad’s SH updated at the end of April.
Dave859
Message 22 of 34
Is that also for the BT hub 6 or just the new g fast super hub ? Hope it is as BT haven't give me the super hub. My current firmware is SG4B1000B522.
mattanorak
Message 23 of 34
Got my SmartHub 6 yesterday and it's installed and ready for changeover to Ultrafast, so I'll be able to let you all know if the latest firmware fixes this.  Mine updated itself yesterday as soon as I plugged it in from whatever was the default to SG4B1A006018.
mattanorak
Message 24 of 34
I can confirm that if you have a Smarthub 6 with "Ultrafast" on the front with the latest update (mine has SG4B1A006018), then there's no issue with 330 down / 50 up.  This is what I'm getting at the moment:
DSL uptime:
1 Days, 19 Hours 20 Minutes 9 Seconds
Data rate:
50.01 Mbps / 328.58 Mbps
Maximum data rate:
49135 / 328583
Dave859
Message 25 of 34
Looks like I will have to phone up to get the ultrafast model, very odd as if it's the same as the BT hub 6 why are the Devs not updating it, many customers have been told by the fttp team that their infinity 3 and 4 router would be ok for 330/50 on ultrafast 2.
mattanorak
Message 26 of 34
As far as I know they will still work, but should only deliver the max speed that VDSL2 modems are capable of.  Seems there's a limit on the capability of the chipset which means that it doesn't delibver the full potential.  I'd get on to your provider and ask that they send you the Ultrafast Hub, not the HH6.  The product name showing on my stats page of the hub is: BT Hub 6XA.  (There are some differences between hubs as discussed on the forums here, depending on whether you have FTTP or FTTC, but I imagine as you're on a GFast product you have FTTC, so this should be the hub for you).
Dave859
Message 27 of 34
Thanks, I've just phoned the fttp team and they're going to send out the new hub next week.
pippincp
Sage
Message 28 of 34
G.Fast is not a product, Ultrafast is.
Ultrafast will be delivered by 2 technologies G.Fast and FTTP. The same hub will be used for both.
mattanorak
Message 29 of 34
Splitting hairs, but the response is the same - a homehub marked “ultrafast” is needed, not the standard home hub 6.
Dave859
Message 30 of 34
My new hub arrived today and no where on it does it say ultrafast, plugged in and it's running firmware SG4B1000B316 and speed test is still 30 upload. I'm think they have sent another BT hub 6 by mistake.
