nduli
Message 11 of 12
Re: Smarthub issues - mod help needed
no secret just not sure what it is. 🙂
TSO did some checks but couldn't access the smarthub the HH5 showed up no issues with the connection.
I have had a new hub arrive but have told not to plug in and they'd speak to me tues for the top secret next steps 🙂
i suspect these will involve me plugging in the new hub and some careful moniotring of whats happening with it (regular pull down of logs?)
the last 4 hubs have lasted no more that 7days so hopefully get to a conclusion quickly.
Moderator
Moderator
Message 12 of 12
Hi @nduli Thanks for taking my call earlier and good to hear that the last hub is now providing you with a stable broadband connection.
John
