paulyt
Message 1 of 3
Smarthub problem
I have purchased a new smarthub that I am trying to install with infinity fibre to premises.  The fibre cable comes through the wall into the open reach modem via a green connector which I assume is some kind of optical connector, I have tried connecting the smarthub from number 4 lan port to number 1 lan port on the modem without success so after reading the posts here, I assume I need to take out the modem from the equation but how can I interface the green optical connector to the number 4 lan port ?
your help will be appreciated
2 REPLIES 2
Keith_Beddoe
Message 2 of 3
Re: Smarthub problem
You have the wrong type of smart hub, you need a special one for FTTP, which is supplied by BT.
This smart hub has a red WAN connector on it, which connect to the fibre modem.
See http://bt.custhelp.com/app/answers/detail/a_id/59932/~/fibre-to-the-home%3A-check-your-wiring-and-se...
Under no circumstances interfere with the optical input to the Openreach modem, as you will create a fault condition.
paulyt
Message 3 of 3
Ahh that explains it ! Thanks Keith 👍
