Message 1 of 8
Smarthub worse line stats since update
I got the new smarthub update last night and my line stats seems slightly worse than before the update, before was getting download max of 58 meg and upload of 21 meg although I'm on infinity 1 was getting the full 55/10 now getting
Product name: BT Hub 6A
Serial number: **************
Firmware version: SG4B1000B316
Firmware updated: 04-Aug-2017
Board version: 1.0
Gui version: 1.64.0
DSL uptime: 0 Days, 11 Hours 25 Minutes 58 Seconds
Data rate: 9.99 Mbps / 53.85 Mbps
Maximum data rate: 20697 / 54502
Noise margin: 12.9 dB / 6 dB
Line attenuation: 17.3 dB
I know it's not much difference but would of thought things would of stayed the same or slightly better, the only thing that has got better is Line attenuation has gone from 18.1 to now 17.3 not sure why things have gone slightly worse ?
7 REPLIES 7
Expert
Message 2 of 8
Re: Smarthub worse line stats since update
Infinity 1 is 'up to' 52Mb so it could just be more accurate reporting.
It could be interesting to know what happens when the SNR change kicks in for you?
Message 3 of 8
Infinity 1 up to 52mbps refers to the speed you'll see on a speedtest.
It's a 55/10 sync product.
Message 4 of 8
@Webby I know it's a 55/10 product I'm just saying what it used to sync at,
This was before the update
BT Broadband /
BT Infinity /
BT Infinity 3 and 4:
BT Infinity
Firmware version:
SG4B10002244
Firmware updated:
03-Aug-2017
Serial number:
Downstream sync speed:
55.00 Mbps
Upstream sync speed:
10.00 Mbps
Network uptime:
13 Days, 1 Hours 21 Minutes
System uptime:
13 Days, 1 Hours 23 Minutes
BT Wi-fi status:
Not active
Message 5 of 8
Sorry, my post was in reply to @DavidCo
OP, can you put your number into here https://www.dslchecker.bt.com and post up a screenshot of the results.
Expert
Message 6 of 8
@Webby
Responded due to my update to .316 when, as if by magic, my attenuation dropped by 4
All without moveing closer to cab
Message 7 of 8
Still not sure how the up to 52mbps advertising rules have any relation to the sync speed of this customer?
Message 8 of 8
@Webby here's the results
BT BROADBAND AVAILABILITY CHECKER
Telephone Number 01978 on Exchange WREXHAM NORTH is served by Cabinet 5
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
High Low High Low
VDSL Range A (Clean) 69.4 50.7 20 15.7 44 Available -- Yes Yes --
VDSL Range B (Impacted) 56.3 33.7 18 8.5 27.4 Available -- Yes Yes --
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand 330 30 -- Available -- -- -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 5 -- 3 to 7.5 Available -- -- -- --
WBC ADSL 2+ Annex M Up to 5 Up to 1 3 to 7.5 Available -- -- -- --
ADSL Max Up to 2.5 -- 1.5 to 3.5 Available -- -- -- --
WBC Fixed Rate 2 -- -- Available -- -- -- --
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- -- -- --
ADSL Multicast -- -- -- Available -- -- -- --
Premise environment
Status
Bridge Tap N
VRI N
NTEFaceplate N
Last Test Date 16-05-2017
