Nizzyyy
Message 1 of 4
Solid Orange Light FTTP modem?
Hi there
Only just noticed this tonight, my FTTP modem on my wall has a solid orange light above “Charging”. i have searched everywhere and can’t find an explanation, could anyone here help at all?
TIA
3 REPLIES 3
Message 2 of 4
Re: Solid Orange Light FTTP modem?
Its the battery backup unit which is charging the battery, perhaps you had a power cut at some time?
Nizzyyy
Message 3 of 4
Ah I see, more than likely happened when I was out, thanks 😁
Moderator
Moderator
Message 4 of 4
Nice one @Keith_Beddoe  Smiley Very Happy
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
