twangy
Newbie
Message 1 of 7
Some advice on speed limiter
I recently switched back to BT from another ISP. When I was previously with BT my speed was around 44mb/s. With the other ISP I took a package which limited me to a top speed of 40mb/s and I was getting 39mb/s in practice. My new BT connection is getting 37mb/s. My question is would the previous ISP have put a speed limit on at the exchange? If so how can I check that BT have removed it?
6 REPLIES 6
Message 2 of 7
Re: Some advice on speed limiter
Welcome to this user forum.
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Then, if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post lines 1-12
Or post the information from the smart hub, using this link.
http://192.168.1.254/0000012803/gui/#/technicalLog/information
Message 3 of 7
No, it's likely just crosstalk
twangy
Newbie
Message 4 of 7
Thanks for the reply. There are no other devices on the line, it just seems a 7mb/s drop since I last had BT as an ISP seemed high.
Message 5 of 7
If you post the information requested, then you should get a more accurate reply.
twangy
Newbie
Message 6 of 7
Thanks for your help Keith. Pasted results below.
Product name:
BT Hub 6A
Serial number:
Firmware version:
SG4B10002244
Firmware updated:
05-Jan-2017
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
0 Days, 20 Hours 50 Minutes 49 Seconds
Data rate:
9.31 kbps / 39.72 kbps
Maximum data rate:
9313 / 39718
Noise margin:
6.4 / 6.4
Line attenuation:
21.9
Signal attenuation:
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
WBC FTTC 18x2 Provide Availability
WBC FTTC 18x2 Sim Availability
Left in Jumper
High
Low
High
Low
VDSL Range A (Clean)
46.1
32.4
9.1
6.3
Available
VDSL Range B (Impacted)
35.5
20
7.8
4.3
Available
Featured Products
WBC FTTP Availability Date
FTTP on Demand
330
30
Available
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+
Up to 5
3 to 7.5
Available
WBC ADSL 2+ Annex M
Up to 5
Up to 0.5
3 to 7.5
Available
ADSL Max
Up to 3
2.5 to 6.5
Available
WBC Fixed Rate
2
Available
Fixed Rate
2
Available
Other Offerings
Availability Date
VDSL Multicast
Available
ADSL Multicast
Available
Message 7 of 7
Estimated speeds for your line of 32.4 - 46.1meg.
Your line is currently connected at 39.7, pretty much slap bang in the middle of the estimated speeds. There's nothing wrong with your connection.
