Expert
Message 11 of 31
Re: Sorry Mods 5th Time in a Year
recycled again
Information
Firmware version:
SG4B1000B522
Firmware updated:
16-Jan-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 1 Hours 53 Minutes 10 Seconds
Data rate:
15.00 Mbps / 67.00 Mbps
Maximum data rate:
32137 / 93950
Noise margin:
16.3 dB / 12.8 dB
Line attenuation:
15.1 dB
Even the upload speed is dropping now
Test Result
1. Best Effort Test: -provides background information.
 Download Speed
 62.76 Mbps
0 Mbps62.04 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 62.76 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-62.04 Mbps .
 Additional Information:
 IP Profile for your line is - 62.04 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 12.57 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 12.57Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
Expert
Message 12 of 31
Still on its way down
Firmware version:
SG4B1000B522
Firmware updated:
16-Jan-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 34 Minutes 2 Seconds
Data rate:
12.00 Mbps / 60.00 Mbps
Maximum data rate:
32427 / 93215
Noise margin:
19.4 dB / 14.4 dB
Line attenuation:
15.1 dB
On its Death Spriel again
SO Mods could you please resolve this again to the point that i do not have to keep asking you for Help
Test Result
 Download Speed
 54.67 Mbps
0 Mbps55.58 Mbps
 Download speedachieved during the test was - 54.67 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-55.58 Mbps .
 IP Profile for your line is - 55.58 Mbps
 Upload Speed
 10.77 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 10.77Mbps
Recognised Expert
Message 13 of 31
Do you keep rebooting the HomeHub because your connection times are always very short?
If you are then that could well be why the DLM has increased your noise margins as it sees the line as being unstable and areduces the speeds to gain stability.
Expert
Message 14 of 31
Nope
It just recycles for no reason
The Landline has been check
The Broadband says no fault
and no line noise
I have not had any power cuts
Appears to have got worse since new firmware was downloaded
Message 15 of 31
If you haven't already done it after the firmware update try a factory reset of the Homehub by pressing a pin into the recess button on the rear for about 20 seconds.
Expert
Message 16 of 31
Just done the Factory Reset
Information
Firmware version:
SG4B1000B522
Firmware updated:
07-Feb-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 13 Minutes 5 Seconds
Data rate:
Maximum data rate:
31985 / 93725
Noise margin:
19.2 dB / 14.6 dB  These high levels do not help the Speed
Line attenuation:
15.1 dB
Message 17 of 31
The factory reset was not to decrease the noise margin as such, it was to see if it helped to stop the hub's resets which in turn may help the stability and then you may see the speeds increase and noise margin drop.
Expert
Message 18 of 31
Well been away on a winter break for 2 week
Was expecting the worse on my broadband
but WOW back up to top speed again
Information
DSL uptime:
1 Days, 19 Hours 48 Minutes 59 Seconds
Data rate:
20.00 Mbps / 80.00 Mbps
Maximum data rate:
29898 / 94969
Noise margin:
15.6 dB / 9.3 dB
Line attenuation:
15.1 dB
Can only assume the Mods have done something again
cann see how when it was dieing tha the speed could go up again
But the BT Speedtest does not show the speed increase
Test Result
 Download Speed
 43.99 Mbps
0 Mbps74.1 Mbps
 Download speedachieved during the test was - 43.99 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-74.1 Mbps .
 IP Profile for your line is - 74.1 Mbps
 Upload Speed
 12.81 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 12.81Mbps
Expert
Message 19 of 31
Its started again
get home found router rebooted
Information
Firmware updated:
07-Feb-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 11 Minutes 6 Seconds
Data rate:
20.00 Mbps / 74.00 Mbps
Maximum data rate:
32210 / 92344
Noise margin:
14 dB / 10.4 dB
Line attenuation:
15.1 dB
Test Result
 Download Speed
 68.97 Mbps
0 Mbps68.57 Mbps
 Download speedachieved during the test was - 68.97 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-68.57 Mbps .
 IP Profile for your line is - 68.57 Mbps
 Upload Speed
 16.66 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 16.66Mbps
Expert
Message 20 of 31
Mods Is there anyway you can help me sort this speed drop once anf for all
you so far every few month have been involved get visit and the eng just resets the line
no fault on landline no fault on broadband no line noise
speed just starts dropping
you reset this a month back within a few days the speed started dropping
ip profile was at 77.35 now down to 62 mb why
Test Result
 Download Speed
 60.2 Mbps
0 Mbps62.04 Mbps
 Download speedachieved during the test was - 60.2 Mbps
 Upload Speed
 16 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 16Mbps
Information
Data rate:
20.00 Mbps / 67.00 Mbps
Maximum data rate:
32206 / 91680
Noise margin:
13.6 dB / 12.2 dB
Line attenuation:
15.1 dB
The router shows that can do upto 91 to 95 mb so why is the line not staying stable db level of 12.2 does not help
