Moderator
Moderator
Message 21 of 31
Re: Sorry Mods 5th Time in a Year
Hi @Travelusa,
I'm sorry to see that the connection speed has dropped again. I'll be happy to take a look at this for you. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
Expert
Message 22 of 31
Looks like it recycled again whilst i was out.
DSL uptime:
0 Days, 4 Hours 35 Minutes 5 Seconds
Data rate:
19.00 Mbps / 60.00 Mbps
Maximum data rate:
31905 / 93099
Noise margin:
14.4 dB / 14.4 dB
Line attenuation:
15.1 dB
DB levels keep going up.
Test Result
1. Best Effort Test: -provides background information.
 Download Speed
 53.47 Mbps
0 Mbps55.58 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 53.47 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-55.58 Mbps .
 Additional Information:
 IP Profile for your line is - 55.58 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 15.52 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 15.52Mbps
ip pro
 Upstream Rate IP profile on your line is - 20 Mbps
IP profile dieing now
Message 23 of 31
@Travelusa
Is it possible that an electric appliance in your house is generating interference?
The reason I ask this is because you said you went on holiday and when you returned the line stats were fine, as soon as you resumed your daily routine the problem started again.
Expert
Message 24 of 31
Still slow to what it was
Information
DSL uptime:
4 Days, 2 Hours 24 Minutes 32 Seconds
Data rate:
15.00 Mbps / 49.00 Mbps
Maximum data rate:
31025 / 95618
Noise margin:
15.5 dB / 18.3 dB
Line attenuation:
15.2 dB
Even the upload has gone as well
 Down to Infinity 1 Speed
Test Result
 Download Speed
 44.78 Mbps
0 Mbps45.4 Mbps
 Download speedachieved during the test was - 44.78 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-45.4 Mbps .
 IP Profile for your line is - 45.4 Mbps
 Upload Speed
 9.86 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 9.86Mbps
Expert
Message 25 of 31
I may have found my interference
I think it was my Sky Q Box
Thinking back my big troubles started on the broadband from then
When it was install it was connected via the Wireless
After a while i found that it could be connected to the ethernet witch i did ,even though it was setup for ethernet it was still connected via the wireless on as part of the trouble shooting i looked at the Sky Q setting and found the wireless or the ethernet was dropping connection to the router so i think the poor router was getting confused
So it caused it to reset
I have since disconnected the ethernet side
the skq q setting do not show any drops now
And the Router and Broadband ,,the broadband was reset by engineer that called
Has been Stable the noise db levels have dropped from the 20 db to details below
DSL uptime:
6 Days, 19 Hours 33 Minutes 20 Seconds
Data rate:
20.00 Mbps / 80.00 Mbps
Maximum data rate:
28810 / 95906
Noise margin:
15.4 dB / 9.3 dB
Line attenuation:
15.1 dB
Also my IP profile has gone back up from 45 mb to 77.35
So it looks like the Sky Q box and the BT hub6a to not like both Wireless/Ethernet connection from the same device.
So far so good
Just hope where i am moving to soon the Broadband is stable
the BT broadband Cab is just 200 feet from my new home
According to the BT Broadband tester for the address is 80 mb with min of 72 mb
May be able to get the BTTV UHD
Expert
Message 26 of 31
So far so good
Details from router Stable  i will not close off for a few week just incase
Information
DSL uptime:
7 Days, 9 Hours 51 Minutes 18 Seconds
Data rate:
Maximum data rate:
28707 / 93324
Noise margin:
15.3 dB / 8.6 dB
Line attenuation:
15.1 dB
Expert
Message 27 of 31
Thanks Mods
So Far so Good
Information
DSL uptime:
9 Days, 9 Hours 50 Minutes 7 Seconds
Data rate:
Maximum data rate:
28723 / 95991
Noise margin:
15.4 dB / 9.3 dB
Line attenuation:
15.1 dB
Expert
Message 28 of 31
results so far
Information
DSL uptime:
12 Days, 18 Hours 35 Minutes 17 Seconds
Data rate:
Maximum data rate:
28532 / 95505
Noise margin:
15.2 dB / 9.1 dB
Line attenuation:
15.1 dB
Test Result
 Download Speed
 75.42 Mbps
0 Mbps77.35 Mbps
 Download speedachieved during the test was - 75.42 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-77.35 Mbps .
 IP Profile for your line is - 77.35 Mbps
 Upload Speed
 16.2 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 16.2Mbps
So it looks like it was the SKY Q you cannot have both ethernet and the wireless connected  as skyq gets confused and started dropping connection and poor router startes resseting as well
ethernet disconnened only using wireless results above show this 12 days without a dropout.
bet now i close this off problems will start
Thanks MODS for helping again
Expert
Message 29 of 31
O well spoke to soon
reset 20 hrs ago
have not changed any equip or settings
Information
DSL uptime:
0 Days, 19 Hours 39 Minutes 58 Seconds
Data rate:
Maximum data rate:
28472 / 95622
Noise margin:
15.1 dB / 9.1 dB
Line attenuation:
15.1 dB
Test Result
 Download Speed
 75.64 Mbps
0 Mbps77.35 Mbps
 Download speedachieved during the test was - 75.64 Mbps
 Upload Speed
 16.92 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 16.92Mbps
Results appear ok but thats how it all starts.
Recognised Expert
Message 30 of 31
A Hub reboot after 14days is not unusual, many report that it happens like that.
