Message 1 of 17
Speed Issue
Got BT package where it says upto 52 mb but only getting 40 the weird thing is i know my line can handle 60 at a max so why is this.
16 REPLIES 16
Message 2 of 17
Re: Speed Issue
post stats from hub  advanced settings then technical log information
enter phone number and post results  https://www.btwholesale.com/includes/adsl/main.html
Message 3 of 17
Re: Speed Issue
Message 4 of 17
Re: Speed Issue
Thank you for fast reply have uploaded the pictures
Sage
Message 5 of 17
Re: Speed Issue
Any noise on your line? 17070 option 2, best with corded phone.
Message 6 of 17
Re: Speed Issue
Hi have done test and is crackerly with  buzzing.
Message 7 of 17
Re: Speed Issue
@thehypnootoad1
If there is noise on the line, then you need to report it as a noisy line. Do not mention the broadband problem, otherwise it will end up in the wrong fault queue, and take much longer to be fixed. There are plenty of people who can fix phone faults, but not as many broadband people.
Once the phone fault is fixed, then the broadband will get better.
Its important to make sure that the noise is still there, when you are connected to the test socket, like this.  This is to prove that the fault is external to your property.
Message 8 of 17
Re: Speed Issue
Thank you  for your help will test and get back to you.
Message 9 of 17
Re: Speed Issue
lol at your wireless network name - that might alarm some neighbours!
Message 10 of 17
Supposed to be getting 52mb
Hi supposed to be getting 52 mb but only getting 39 the funny thing is my previous ISP was Plusnet and was getting a maximum of 60 so i know i can get the speeds I had a engineer out to check line for noises on phone and got all clear but still anyone know why only getting 39 thanks Ash.
