Message 1 of 8
Speed Test.
Hi all. My Infinity service just started last Wednesday and i've tried to do a speed test a few times now as i've thought there might be a problem. The checker simply doesn't seem to produce any results and only goes to a page asking me if i want to report another problem????
Is there a problem with the speed test at the moment or is this normal when you first get Infinity?
Telboy.
7 REPLIES 7
Message 2 of 8
Re: Speed Test.
What website you using?
Message 3 of 8
Re: Speed Test.
BT's speed test.
Recognised Expert
Message 4 of 8
Re: Speed Test.
Use this one (http://speedtest.btwholesale.com/) not the BT Consumer test.
Regards
Message 5 of 8
Re: Speed Test.
Ah right, thanks pal. I'll do that. Thank you.
Message 6 of 8
Re: Speed Test.
This can't be right surely? Admittedly, i did the test on wireless but even before i got Infinity i was getting 14-18 Mbps. here is the stats from the test i just did.
Download 3.94
Upload 8.20
Message 7 of 8
Re: Speed Test.
Run it with a wired connectipn first.
Can you post up the connection stats from the home hub?
Message 8 of 8
Re: Speed Test.
I'll do that but i can't tonight as i'm just about to go out. I'm afraid i wouldn't know how to post stats from the homehub. I'm not too good at this sort of thing.
Thanks for your reply.
