Message 11 of 21
Re: Speed and address anomaly - database error?
Doesn't seem worth it in that case - I am assuming it would be the same for the flats as they are on the same DP and same distance to the cabinet?
With respect to the address/database issue, are there any mods on here that can help?
Message 12 of 21
Bumping for the attention of any mods that can help with the addressing issue.
Sage
Message 13 of 21
I've flagged for a mod. One should be long shortly.
Message 14 of 21
Message 15 of 21
While you’re waiting for a mod, best bet would be to fill out this formwize https://www.formwize.com/run/survey3.cfm?idx=505d040e0b080d to query this directly with the fibre availability enquiries team at Openreach.
Moderator
Moderator
Message 16 of 21
Hi @NewNewbie
Your best bet would be to use the link that @Saruman has posted above.  This will go directly to Openreach who will be able to confirm fibre status at each address.
Cheers,
Robbie
Message 17 of 21
I filled in the form above and have just got the following, so, fingers crossed that I am on the right path:
Thanks for contacting us.
I've had a look at this for you and it looks like your query will need some further investigation by our specialist team to resolve.
What I'm going to do is forward your query on to them directly, which they will then pick up and deal with, contacting you directly once they have the relevant details.
Sorry I wasn't able to deal with your issue today, but our specialist team will be in touch as soon as possible.
Best wishes
Pushpender
Fiber Enquires
Message 18 of 21
Doesn't appear I am getting anywhere with this.
On the 3rd of October I got the following e-mail which shows my original query wasn't even read. I wrote back the same day but haven't heard anything back.
What else can I now do?
Good Morning Mr X,
Thanks for getting in touch regarding fibre availability for your address.
Cabinet 10, which serves your area, is currently out of capacity due to high demand. We've contacted our fibre capacity team who will advise when the cab capacity will be increased. As soon as we hear back from them we'll update you accordingly.
Kind regards
Neil Colk
Infrastructure Solutions
Message 19 of 21
Bump.
Can ANYONE help with this?
Message 20 of 21
you just need to wait on openreach getting back to you - or you could keep hassling openreach
there is no timescale for cab capacity increases
