sps1013
Message 1 of 15
Speed below min guaranteed and handback threshold
Evening,
I have previously had a super connection in the 55/9 range for the last 18 months on Infinity 1. The setup has been exactly the same with no changes to anything.
However, the last couple of weeks browsing has been slow so I have been monitoring my connection. I do not have a homehub, used to have a 5A but it stopped working so reverted to my HG612 (not unlocked) which I have had for a few years. I have had the HG612 plugged in since moving to this property 18 months ago.
I am connected to the master socket and have taken the following readings in the test socket.
I have done a quiet line test with a corded phone and cannot hear any crackles, hissing or anything.
My contracted minimum guaranteed speed is 55Mbps with a range of 63-80Mbps on my contract email which was renewed in November 2017. I was offered the increased speeds on Infinity 1 as an existing customer and my speed did rise to the low 70's and a 19 upload.
Can anybody please advise the next step which hopefully does not involve going through everything again!
Thanks.
14 REPLIES 14
Message 2 of 15
Re: Speed below min guaranteed and handback threshold
are you using a router at all or have you just conencted your pc direct to HG612 modem?
without any stats from the modem or router it is difficult to tell if your speed is low duw to disconenctions and high noise margin due to the DLM taking action to stabilise your conenction
your download speed is good for your profile
sps1013
Message 3 of 15
I use an Apple AirPort Extreme as my router.
If my download is good for my profile why the huge drop from previous stable line conditions? Why am I below min guaranteed speed?
I haven’t touched my HG612 and we have had no power cuts.
sps1013
Message 4 of 15
Do we still use Range A for connections? Because I certainly was always on that
Message 5 of 15
without some router/modem stats to consider there is no way of telling from the restricted information posted
eg  you may have an attainable of say 70mb but your connection speed about 43mb with a noise margin much higher than normal 6db suggesting connection/reset problem
sps1013
Message 6 of 15
Ok, understood.
I can not unlock my modem as I run on an all Mac setup. I suppose the only thing I can do is try and borrow a HH and get a snapshot of the line stats.
Message 7 of 15
If that is possible it would help and also help if you need engineer visit
Message 8 of 15
@sps1013 wrote:
Ok, understood.
Or borrow a device with an Ethernet port, it only takes 5 minutes to unlock the HG612.
sps1013
Message 9 of 15
Hi,
I have borrowed a HH5 type A and have connected to the test socket. I waited 30 mins between switching off my HG612 and turning the HH on.
Speedtest much better and the line stats are also below.
Now I am guessing it is my HG612 that is possibly faulty? If it is then I need to get a new one or keep the HH5 and disable wireless and configure my Apple extreme.
Message 10 of 15
stats look good so does look like faulty modem
