fenixriot
Message 1 of 13
Speed decrease to the property.
I was getting 55mb to the property, which had dropped to 14mb, but has gone back up to 44mb, but it is still 11mb less than i was getting. Spoke in online chat to no avail, as i got the usual it is within the limits, which is all well and good but when im only getting real world download speeds of 37mb compared to what i used to get which was 51mb, i dont find this acceptable.
Any help would be appreciated.
12 REPLIES 12
imjolly
Message 2 of 13
Re: Speed decrease to the property.
post the stats from your hub  if hh6 then advanced settings then technical log information
enter your phone number and post results  remember delete number  https://www.btwholesale.com/includes/adsl/main.html
fenixriot
Message 3 of 13
This is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084316+NQ74317524
Firmware version:
SG4B1000B540
Firmware updated:
23-May-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 44 Minutes 31 Seconds
Data rate:
10.00 Mbps / 44.00 Mbps
Maximum data rate:
11469 / 48003
Noise margin:
7.5 dB / 7.2 dB
Line attenuation:
19.9 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
37 MB Uploaded / 416 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-GHMP
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-GHMP
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
A0:39:EE:5A:91:79
Software variant:
Boot loader:
9.2.0
imjolly
Message 4 of 13
As you have a connection speed of 44mb which is within your estimated range BT won't help
have you been having connection problem with line dropping or have you been resetting router to try and improve speed or maybe a combination of both?
you need to maintain a stable connection with no resets and the DLM will eventually activate G.INP  which will reduce your noise margin nearer 3db and give an increase in connection speed
fenixriot
Message 5 of 13
How long can this take approx?
imjolly
Message 6 of 13
if you are not having problems with connection dropping then about 10/14 days
fenixriot
Message 7 of 13
Just a quick update, im now at the 10 day mark and still no change. I will wait a few more days and if no change still, then i will get in touch with BT.
pippincp
Sage
Message 8 of 13
Is there any noise on your line? 17070 option 2 best with corded phone. Any noise report a line fault on 151.
fenixriot
Message 9 of 13
I did the phone line test and all fine. I noticed the internet had reset itself last night, but no change to speed.
fenixriot
Message 10 of 13
I have now been incontact with supports several times now, and as the line has no fault and my speed is within their accepted range, there is not a lot that can be done from the looks of it.
What makes it frustrating is the fact that several weeks ago i was getting 55mb to the hub giving me a respectable 51mb real world download speed, now its 44mb to the hub and between 32 and 40mb real world download speeds.
I would just love to know how i can lose 10mb and they say its fine, especially as before i was on infinity 1, we had infinity 2 and the line was capable of around 67mb to the hub and about 60mb real world.
I just dont get it. Losing my patience with BT.
