MK10
Message 1 of 2
Speed drop after upgrade from Infinity 1 to Infinity 2
I was initially on Infinity 1 receiving a consistent 52mb. After not yet receiving the free speed upgrade, I called up and after some hassle they upgraded me to Infinity 2. My download speed has now dropped to 45mb, though my upload speed has risen to 14mb, from about 9 or 10, if I remember correctly. The upgrade happened on Thursday. Any ideas on why my speed has dropped? Thanks for any help.
Firmware version:
SG4B1000B522
Firmware updated:
21-Jan-2018
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
1 Days, 6 Hours 1 Minutes 57 Seconds
Data rate:
14.30 Mbps / 45.22 Mbps
Maximum data rate:
14339 / 47657
Noise margin:
6 dB / 6.7 dB
Line attenuation:
17.6 dB
Signal attenuation:
VPI / VCI:
0/38
1 REPLY 1
imjolly
Message 2 of 2
Re: Speed drop after upgrade from Infinity 1 to Infinity 2
have you tried a factory reset to see if that helps?
are you using the test socket with a filter to see if that improves your conenction?
try quiet line test  dial 17070 option 2 should be quiet and best with corded phone
