L3
Message 1 of 10
Speed drop again
hi guys.
Can you have look at this stats and be tell me what u think. Had a engineer out few months ago said was loop fault and he didn't recommend power line adapters, I've not used them since then and switched to sh2.  But connection keeps getting banded.   Line only lasts few months before starts to drop speed. This now gone from 46-47,  43999, 39999 now 35
Product code:Smart Hub 2
Serial number:+091298+2012005641
Firmware version:v0.21.03.07094-BT
Firmware updated:Tue Oct 13 12:52:38 2020
Board version:R01
GUI version:1.56 15_02_2019
DSL uptime:9 days,00 Hours59 Mins16 Secs
Data rate:7.665 Mbps / 35 Mbps
Maximum data rate:7.661 Mbps / 45.552 Mbps
Noise margin:6.1 / 10.1
Line attenuation:10.7 / 21.3
Signal attenuation:10.7 / 21.5
Thanks guys
9 REPLIES 9
pippincp
Sage
Message 2 of 10
Re: Speed drop again
Any noise on your line? 17070 option 2.
imjolly
Message 3 of 10
Certainly looks like a line connection problem with connection dropping from one banded profile to another as problem gets worse
L3
Message 4 of 10
  • Cheers guys.
Should that noise margin be that high.  Here it is from today
Maximum data rate:7.661 Mbps / 45.941 Mbps
Noise margin:5.9 / 10.3
imjolly
Message 5 of 10
Normally noise margin about 6db or lower if G.INP active
your noise margin is high as your connection is seen as unstable and DLM has increased your noise margin and reduced your speed and in fact put you in banded profiles. You have been dropping in banded profiles suggesting a line problem which needs engineer visit
L3
Message 6 of 10
I've had bt engineer out before about it last time was 6th june he said was loop fault and changed faceplate. Again before that bt engineer said was hr fault.
End June 2020 was 43999 and I had engineer out beginning June that said was loop fault,faceplate change and couldn't do lift n shift and dlm reset.
June 43999
August 43998
September 39999
November 35
What my next course of action another BT complaint.
Thanks guys
imjolly
Message 7 of 10
ther is no point in a DLM reset as you have an unstable conenction as can be seen with your reducing connection speed dropping from one banded profile to another.  You need to get a stable connection first and that means another engineer visit
L3
Message 8 of 10
Should a smart hub 2 do a recycle at 5pm in afternoon ain't it usually 2am.
Board version:R01
DSL uptime:0 days,05 Hours04 Mins45 Secs
Data rate:7.706 Mbps / 35 Mbps
Maximum data rate:7.706 Mbps / 45.921 Mbps
Noise margin:6.1 / 10.4
Line attenuation:10.7 / 21.4
pippincp
Sage
Message 9 of 10
imjolly
Message 10 of 10
There is no set time for a hub reset especially if there is a problem with line noise
