goral
Message 1 of 7
Speed drop from 68 to 42 mbps
Hi
It is possible to by downgrade from 68mpbps to 42 mbps?
I have test result from a year ago and was 68mbps and last week only 42!
6 REPLIES 6
Guru
Guru
Message 2 of 7
Re: Speed drop from 68 to 42 mbps
Hi goral,
please can you run a BT speed test (including IP Profile) The link is: http://speedtest.btwholesale.com (not beta version)[Best done with a wired, Ethernet, connection] After Quick Test is done you need to click "Further Diagnostics" to get IP Profile.
Then post the results here please. It should look something like this:
2) what does it say in the grid for WBC FTTC when you go to http://dslchecker.bt.com/adsl for your landline number.
Cheers
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
goral
Message 3 of 7
WBC FTTC -:
WBC FTTCUp to 42.7Up to 6.5--Available
I know it looks like I have maximum but, year ago was 68 so what happen?
Message 4 of 7
@goral can you please post the results of the BT speedtest as jac_95 has asked for
goral
Message 5 of 7
Results Image not loaded
1. Best Effort Test:  -provides background information.
 Download Speed
 32.2 Mbps
0 Mbps47.72 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 32.2 Mbps
 For your connection, the acceptable range of speedsis 16 Mbps-47.72 Mbps .
 Additional Information:
 IP Profile for your line is - 47.72 Mbps
2. Upstream Test:  -provides background information.
 Upload Speed
 7.38 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 7.38Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
We were unable to identify any performance problem with your service at this time.
It is possible that any problem you are currently, or had previously experienced may have been caused by traffic congestion on the Internet or by the server you were accessing responding slowly.
If you continue to encounter a problem with a specific server, please contact the administrator of that server in the first instance.
Please visit the FAQ if you are unable to understand the test results.
Distinguished Expert
Message 6 of 7
I can't see 42 mbps anywhere outside of the subject?
To say thanks for a helpful answer, please click the white star
Message 7 of 7
@goral wrote:
WBC FTTC -:
WBC FTTC Up to 42.7 Up to 6.5 -- Available
That looks like you have been using the dsl checker not a speed tester. This is only an estimate of what your line may get. It is not what your line will get. BT have revised their estimates so it may have been higher last year.
