viper76
Message 1 of 17
Speed drop !!!!
Hi
I have had bt infinity since last March and I was getting a solid 78.12mb download speed without any problem 2 weeks ago the speed drop it to 69mb and yasterday drop it again to 57mb and do not know why I have tried to get help using cs chat but they have not got a clue ?
Any hep please .
16 REPLIES 16
Distinguished Guru
Message 2 of 17
Re: Speed drop !!!!
Do you have a HH5 ?
If not, I'll try again 🙂
Message 3 of 17
Re: Speed drop !!!!
Can you run this checker and post back a screen shot of the results. Make sure you delete your phone number before posting.
http://www.dslchecker.bt.com/adsl/adslchecker.welcome
and use this speed tester then carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
If you have a Homehub 5 can you also post the stats from 1-12 by logging onto the homehub management pages then troubleshooting > helpdesk. http://bthomehub.home/
viper76
Message 4 of 17
Re: Speed drop !!!!
yes I have HH5
Distinguished Guru
Message 5 of 17
Re: Speed drop !!!!
Can you post your line stats from the HH5 please? These are in Troubleshooting/Helpdesk on the web interface at http://192.168.1.254
viper76
Message 6 of 17
Re: Speed drop !!!!
Back on Last March this was my line speed
6. Data rate:19999 / 79995
7. Maximum data rate:41879 / 112560
8. Noise margin:23.8 / 15.1
9. Line attenuation:0.0 / 14.3
10. Signal attenuation:0.0 / 14.3
now
6. Data rate:19999 / 59078
7. Maximum data rate:32331 / 80725
8. Noise margin:10.9 / 7.6
9. Line attenuation:16.1 / 14.3
10. Signal attenuation:16.2 / 14.3
viper76
Message 7 of 17
Re: Speed drop !!!!
1. Product name:BT Home Hub
2. Serial number:+068343+NQ34646876
3. Firmware version:Software version 4.7.5.1.83.8.204 (Type A) Last updated 18/01/15
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 00:19:16
11. Data sent/received:0.0 MB / 0.0 MB
12. Broadband username:
bthomehub@btbroadband.com
Distinguished Guru
Message 8 of 17
Re: Speed drop !!!!
How come your uptime is only 19 minutes?
viper76
Message 9 of 17
Re: Speed drop !!!!
Because I rebooted the HH5 .
Distinguished Guru
Message 10 of 17
Re: Speed drop !!!!
The raised noise margin indicates instability on your line.
This is often due to a line fault which will require an engineer visit to fix.
