Harry11c
Newbie
Message 1 of 2
Speed dropping/IPV6
Hi im new on here any help would be greatly appreciated. I’ve been having trouble with my broadband since upgrading in November. Every couple of weeks my internet seems to disconnect for about 2/3 minutes and the latest disconnect (2 nights ago) has caused my download speed to drop from 62mbps to 44bps and now my IPV6 is gone. I have spent multiple hours in chats and on the phone to bt with no help. I only use the internet for 2 Xbox ones which are both wired.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Speed dropping/IPV6
Hi @Harry11c
Welcome to the Community and thanks for your post!
Sorry that you're experiencing broadband drops.  All the disconnects may have resulted in the slower speed.  Can you post your Hub stats?  (Enter 192.168.1.254) into a web browser on a device connected to your Hub.
Smart Hub - Advanced settings>Technical Log
Hub 5 - Advanced settings>troubleshooting>Helpdesk
For more info on this check out >> Learn about the BT Hub Manager <<
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
