shermsta
Message 1 of 7
Speed dropping slowly
Hi,
I ordered fibre 2 years ago the same week it became available in my area and got a good speed of 74mb. Slowly over the 2 years it has crept down until now its at 59mb. It seems to lose speed every month.
Data Rate: 20000 / 63905
Maximum Data Rate: 22446 / 63914
Noise Margin: 7.2 / 6.4
Line Attenuation: 19.7 / 15.5
Signal Attenuation: 0.0 / 0.0
What happens is the noise margin start off at 6.5 then goes down to like 6 which then causes a re connect which goes back up to 6.5 but then ive lost speed. this happens like once a month.
Anyone got any ideas?
6 REPLIES 6
Message 2 of 7
Re: Speed dropping slowly
Can you put your number into here http://www.dslchecker.bt.com and post up a screenshot of the results?
shermsta
Message 3 of 7
Message 4 of 7
You're within the estimated range for yor line.
shermsta
Message 5 of 7
is the estimated speed not 61.5? im getting 59.
As the cabinet fills up with connections does the speed generally fall due to less capacity?
Message 6 of 7
You're getting 64 not 59. Speed generally falls as the cabinet fills due to crosstalk interference, not less capacity.
Message 7 of 7
The ranges on that checker refer to sync rate. Your hub is connected at 63.9.
