Dezza88
Message 1 of 14
Speed increase
I was told by email last year that my speed would be going up as a loyal customer, even when I renegotiated my contract they said I would still get this offer. 2 months on and other family have had their boost but not me. I used to get over 50mb on the line now struggle to get 40mb could anyone help or advise as I have seen people saying they have had profile change requests to increase speed. Any help much appreciated
13 REPLIES 13
imjolly
Message 2 of 14
Re: Speed increase
Can you enter your phone number and post results. Remember delete number only. https://www.btwholesale.com/includes/adsl/adsl.htm
Can you post the stat stat from your router. If hh6 then go to advanced settings then technical log information
Dezza88
Message 3 of 14
Re: Speed increase
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
High Low High Low
VDSL Range A (Clean) 69.1 49 20 13.8 40.7 Available -- --
VDSL Range B (Impacted) 56.9 35 17.8 9.7 30 Available -- --
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand 330 30 -- Available -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 4 -- 3 to 5 Available -- --
WBC ADSL 2+ Annex M Up to 4 Up to 1 3 to 5 Available -- --
ADSL Max Up to 4 -- 3 to 5 Available -- --
WBC Fixed Rate 2 -- -- Available -- --
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- --
ADSL Multicast -- -- -- Available -- --
Premise environment
Status
Bridge Tap N
VRI N
NTEFaceplate N
Last Test Date 18-05-2017
Dezza88
Message 4 of 14
Re: Speed increase
Forgive me for sounding daft but do you want me to copy and paste the tech log info ?
imjolly
Message 5 of 14
Re: Speed increase
If hh6 then the technical log information not the actual technical log. Should show hub info connection time,connection speed, attainable speed, noise margin etc
Dezza88
Message 6 of 14
Re: Speed increase
Product name: BT Hub 6A
Serial number: +084319+NQ70168872
Firmware version: SG4B1000B522
Firmware updated: 13-Jan-2018
Board version: 1.0
Gui version: 1.64.0
DSL uptime: 1 Days, 21 Hours 44 Minutes 29 Seconds
Data rate: 17.42 Mbps / 42.61 Mbps
Maximum data rate: 18048 / 42211
Noise margin: 6.5 dB / 5.8 dB
Line attenuation: 18.3 dB
Signal attenuation:
VPI / VCI: 0/38
Modulation: G_993_2_ANNEX_B
Latency type: Fast Path
Data sent / received: 165 MB Uploaded / 2528 MB Downloaded
Broadband username: bthomehub@btbroadband.com
BT Wi-fi:Active
2.4 GHz wireless network name: BTHub6-8M2H
2.4 GHz wireless channel: Smart (Channel 11)
5 GHz wireless network name: BTHub6-8M2H
5 GHz wireless channel: Smart (Channel 36)
Wireless security: WPA2 (Recommended)
Wireless mode: Mode 1
Firewall: On
MAC address: 24:7F:20:A7:45:F9
Software variant: -
Boot loader: 7.33.1
Dezza88
Message 7 of 14
Re: Speed increase
Thanks for the help so far. Like I said I used to get 50mb when I first got hh6 but then has decreased. I’m hoping that I can get a boost somehow.
imjolly
Message 8 of 14
Re: Speed increase
At present you connection speed is about attainable with noise margin about normal 6db leaving no scope for faster speed
connection time is less than 2 days was that router dropping connection or manual reset?
are you using the test socket with a filter to see if that improves speed by eliminating your internal wiring
try quiet line test. Dial 17070 option 2. Should be quiet and best with corded phone
Dezza88
Message 9 of 14
Re: Speed increase
Brand new line last year from master socket all the way up to the pole outside, the last couple of days the router has dropped out around 10oclock with orange light and then restarting fine.there is no internal wiring as such from master socket goes straight out of the house wall and up to the pole as I said all that wiring was new last year and when I was getting my 50mb. Only have a cordless phone but will try a quiet line test now
Dezza88
Message 10 of 14
Re: Speed increase
No noise on quiet line test so not sure what that means. Hope that helps. Is there any change my account profile is banded somehow ??
